google logo
Only Search Mopar1973Man.Com
Idaho Turbo Diesels Idaho Turbo Diesels
Results 1 to 7 of 7
Thread: Hydroboost Leaks
  1. #1
    Join Date
    Feb 2009
    Location
    Colorado
    Posts
    202
    Points
    31,049
    Level
    26
    Default Hydroboost Leaks
    I have seen the question asked a million times on other forums. It usually comes down to someone claiming to be an awesome mechanic stating that hydroboost brake boosters aren't rebuild-able/resealable or that they are so complicated if you took them apart you would never get them back together.
    Well even though my hydroboost has been doing a great job keeping my undercarriage lubricated the constant top offs with power steering fluid and air in the system got pretty annoying. I decided that I would take a peek inside of it and possibly reseal it. I didn't plan to rebuild the unit as there are a couple specialized tools you either have to purchase or improvise.
    First off when my power steering system wasn't low and had set for a bit to allow the air to work itself out the brakes worked fine. Once the booster saw air it was hard to push them and they had a tendency to jerk. So in other words my booster was functioning. Just leaking fluid and drawing air.
    I started off by finding a kit. I purchased a MBM #50 kit that cost me $25 through piratejack brakes.
    Next I flushed the system, not that it needed it because it went through powersteering fluid constantly.
    Removing the brake booster is frustrating because of course it requires you to remove 4 nuts and the pedal rod from under the dash. The pedal rod is held on by a washer and clip. The 3 out of the 4 nuts were quickly removed using a 3/8 air ratchet, swivel, extensions, and a 15mm deep socket. The last one was removed using a ratchet, short extension, and a deep 15mm socket.
    Of course there are 2 15mm holding the master cylinder to the booster. Two pipe fittings 16mm (power steering), and a hose that is held on by a clamp (also power steering).
    Afterwards I had to remove two plastic line holders from the brake lines to allow them to move a bit. Then I merely slid the master cylinder off it's studs and moved it to the side being careful not to bend the brake lines. I found this gave me the benefit of not having to bleed the brakes and bench bleed the master.
    At this point carefully manipulated the booster out of the truck.
    Once on the floor I placed it on a rubbermaid container lid to catch any fluid that spilled out once opened. I removed 2 15mm nuts that held on the adapter plate that bolts to the master cylinder. At this point a star retainer, spring, rod, and plastic washer will come out. The star retainer will come off by itself but the spring, rod, and plastic washer assembly should remain as one piece.
    Next I removed the 5 3/8" bolts that held the casings together. It took very little persuasion to separate the case halves. It is important to note at this point I remembered I had forgot to apply the brakes 10 times with the engine off to de-pressurize the booster. Not such a big deal cause I had no intentions of removing the gas canister on the booster anyway. Once the halves began to come apart the spool valve fell out. Not a big deal as it can only go back in one way. Oddly enough I found the check valve was missing and in the back of the casing. I noticed matching marks on the check valve and housing right behind the fork on the pedal rod. I am still not sure what happened here, cause the booster seemed to work. All parts were accounted for so I moved on to resealing it.
    I removed the original figure eight seal that sits between the two housings. Comparing the new and the old as well as looking at marks on the housing it would seem this was my problem seal. The old seal was considerably thinner, probably due to shrinking. The new seal can be pushed into place with fingers.
    Next I used some small hooks that I had to fish the piston seal out of the piston bore without damaging the bore. Pay attention to the orientation of the piston seal when removing it. Once again the new seal can be installed simply by fishing it in there and working it in with your fingers.
    I now reinstalled the check valve and the spool valve. I connected the pedal rod to the spool valve and reinserted the piston into it's bore.
    Just as before press the housings back together, this shouldn't take anymore than hand force. Reinstall the 5 3/8" bolts and snug them down. Back on the other side of things reinsert the spring, rod, and washer assembly. Place the star retainer back on the rod making sure to have the curved points toward the inside.
    Reinstall the master cylinder adapter over this, it will retain the spring assembly. Tighten the 15mm nuts.
    After that it is pretty much reverse of removal. Place the booster back in the truck. Tighten the 4 15mm nuts under the dash that retain it to the firewall. Reinstall the pedal rod, washer, and clip. Back under the hood reconnect the power steering lines, and master cylinder.
    Top off the system with power steering fluid and work the wheel back and forth, lock to lock while pressing the brake pedal. It will feel funny at first but it will tighten up as the fluid gets to it. You may hear strange noises due to the air in the system but don't worry the air will work it's way out after sitting for a bit.
    I have yet to notice a leak. Took her on a trip around the neighborhood for a bit after degreasing everything and haven't noticed anything new. My brakes even feel stronger. Hopefully this helps someone not spend $200 over a simple leak.
    2000 Dodge Ram 3500 4x4, NV5600, AirDog 150, Edge Attitude/Juice
  2. The Following User Says Thank You to cummins2k For This Useful Post:
    balsip (05-12-2011)
  3. #2
    Join Date
    Nov 2009
    Location
    Dayton, Or
    Posts
    429
    Points
    46,680
    Level
    32
    Default
    Good write up with pics.
    99 Dodge Cummins Turbo Diesel. 2500 Quad Cab Short Bed. 4X4. Automatic Transmission 47RE. Edge Ez. Raptor Fuel Pump 150. ScanGauge II. Isspro EGT, Tranny, and Fuel Pressure Gauges. ATS Exhaust Manifold. Turbo Timer. Crankcase Vent Mod. B&W Turnover Hitch.
  4. #3
    Mopar1973Man's Avatar
    Mopar1973Man is offline
    AKA: Michael Nelson
    Owner / Administrator Personal Achievements:
    Social Butterfly 10 Referrals 100 Thread Tags 700,000 Experience Points
    Join Date
    Aug 2007
    Location
    New Meadows, Idaho
    Posts
    9,831
    Points
    703,884
    Level
    64
    Follow Mopar1973Man On Twitter Add Mopar1973Man on Facebook Add Mopar1973Man on Google+
    Add Mopar1973Man on Linkedin Visit Mopar1973Man's Youtube Channel
    Default
    Thank you for the wonderful write up and it will get converted to the static pages... Once again Thank you!
    2002 Dodge Ram 2500, 5.9L Cummins Turbo Diesel, 5 Speed NV4500 transmission, 4x4, 3.55 Gears, AirDog 150 fuel pump with 1/2" Big Line Kit, Stock Bosch VP44 Injection Pump, Vulcan Performance Injectors +50HP, Edge Comp Performance Box, BHAF (Big Honkin' Air Filter), Stock Holset HX35W Turbo, Straight 3" Pipe Exhaust, Crankcase Vent Mod, High Idle Mod, MPG / IAT fooler Mod, ScanGauge II, 25% Tinted Windows, DiPricol Gauges (Fuel pressure, Boost, Pyrometer), 235/85 R16 tires mounted on 16x7 Aluminum mags (weighing 62#), Custom Fog Lights, Custom Backup lights, Silverstar Headlights, 23-24 MPG
    1996 Dodge Ram 1500, 5.9L Magnum V8 Gasoline Engine, 46RE Automatic Transmission, 4WD with CAD axle with 3.55 Gears, Mopar Performance PCM, Gutted Kitty, ScanGauge II, 35% Tinted Windows, 16-17 MPG
    2000 Jayco Eagle 296 FBS Travel Trailer, Inside battery cutoff switch, Analog Volt meter, Slide out living area, Digital to Analog TV converter, and much more.
    "The Forum Family of Dodge Ram Trucks with Cummins Turbo Diesel Engines"
    Posted only with Ubuntu Linux 12.04 LTSMicrosoft Free Computers
  5. #4
    AKA: Michael Nelson
    Join Date
    Aug 2007
    Location
    New Meadows, Idaho
    Posts
    9,831
    Points
    703,884
    Level
    64
    Default
    To show you my thanks... Your hydrobooster article is posted on the web site... Thanks!
    http://mopar.mopar1973man.com/cummin...hydroboost.htm
  6. #5
    Join Date
    Dec 2011
    Location
    lake charles, la
    Posts
    3
    Points
    518
    Level
    1
    Default
    I resealed my hydoboost according to this write up, but I can't seem to get all the air out of the lines.
    I turned it lock to lock mutiple times while pumping the brakes. Took it for a ride down the road. Still no luck.
    Any help is muchly appreicated.
    Thanks
    Brian
    To add, it sounds like its low on fluid humming sound. I've added fluid but it ends up over flowing once it gets warm.
  7. #6
    Join Date
    Jan 2011
    Location
    Rochester, NY
    Posts
    381
    Points
    31,023
    Level
    26
    Default
    How long has it sat Brian? If you're not introducing new air through a leak it can still take a couple shales for the cavitated fluid to settle out an finish working the air out.
    Michael Maskalans - here's what you've missed
    '07 Ram 3500 - QC C&C 4x2 6.7/6sp; 3.42s; C&M steel flatbed. 245/70r19.5.
    FOR SALE: '97 Ram 3500 - CC Eaton RTOO 9513 13sp; '01 24v, p-pumped, 4k gsk, broken ring? Banks brake & 4" exhaust.
    '98 Dakota - CC 318/auto; D60/10.25; 42" SX IIs; then | now | build
  8. #7
    Join Date
    Dec 2011
    Location
    lake charles, la
    Posts
    3
    Points
    518
    Level
    1
    Default
    Quote Originally Posted by mr.mindless View Post
    I did the job last week, didn't start the truck till yesterday. Messed with it yesterday and today trying to get the air out.
    I turned the wheel side to side while pumping the brakes, with the truck on and off. It sometimes feel normal but goes back to feeling like no power steering at all. I've added fluid cause it sounds low, but it overflows after turning it side to side mutiple times.
    I'm almost to the point of pulling it off to make sure I did the job right. Should my pedal feel really stiff?
    Thanks for the reply!
    Ok I messed with it some more today without luck. It does sound better, it isnhumming and foaming out the top.
    It is still too hard to steer to drive. Feels like it doesn't have power steering at all.
    Also I pumped the brakes so hard I mus hae cracked a line or something cause I had to bleed the brakes.
    I'm pretty close to pulling it back off and re installing it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
